Electrical help?What did I do now??
Old Apr 11, 2009 | 07:47 PM
GrtDanes's Avatar
GrtDanes
Default Electrical help?What did I do now??
Well boys I was happier than a pig in S....T when I finally got my shifter working.Connected up all my wiring and put a ground on the pos on alternator.Needless to say when I hooked up the battery pos ..all hell broke loose.Sparks flying,battery arking and smoke from the alt.Think I fixed that problem but now I dont have power to anything,but starter and alt..No gauges,radio windows,anything.Turn the key you can hear the beatle walking and nothing else.Any help out there on what I hell I did and what to check now???All fuses look good also in fuse box?
Old Apr 11, 2009 | 07:56 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I would say you got one of the fusible links somewhere. I don't know what year car you have but I do know one is near the starter on most all cars.
Hopefully someone will be with the same year car as yours and can lend a hand.
Old Apr 11, 2009 | 08:01 PM
Duke94's Avatar
Duke94
Yep, one of the fusible links is kaput.
Here is the schmatic for my 78', I would think your 80' is simular. You can see that link "B" goes to the gauges turn sigs etc. and "A" goes to the headlights. Find the wires coming off the starter solenoid, it looks like the red one is the one you popped.
Old Apr 11, 2009 | 08:03 PM
Ganey's Avatar
Ganey
Ya blew the fusible links- start at the starter you should be able to feel the fusible links & tell they are melted.
PS I don't blow the fusible links- not rec.
Old Apr 11, 2009 | 08:06 PM
GrtDanes's Avatar
GrtDanes
It's an 80.Theres two fuseable links going to starter.Are they different voltages or do I just get links and repair??Dont know know much about them but they are there.
Old Apr 11, 2009 | 08:35 PM
Eddie 70's Avatar
Eddie 70
You could probably reach down to the links and feel of them. The soft one is going to be the bad one. If you cannot tell which is softest, try pulling on them from opposite ends. The one that stretches is the one that needs replacing.
Old Apr 11, 2009 | 08:47 PM
GrtDanes's Avatar
GrtDanes
Thanks guys will crawl under her again.Let you know tommorrow the outcome.
Old Apr 11, 2009 | 09:37 PM
GrtDanes's Avatar
GrtDanes
Im guessing this link is a 16ga.link??
Old Apr 12, 2009 | 03:12 AM
RunningMan373's Avatar
RunningMan373
You're actually pretty "Lucky", the alt pos is hooked up direct to the + batt lug at the starter, and the main Batt cable, so it took ALL the current, and did what it was supposed to do- open. Be advised that the current also went through what ever 'Ground' wire you hooked up to the pos alt lug, that will need checking/ replacing also. The rest of your wiring should be ok, though if you can, you might want to replaced the #12 to the alt too, just build the 12 and 16 link into one piece, and replace the whole thing. I would get my wire from a reputable source also, you want true 12 gauge and good insulation- try a good hardware store for 12 gauge stranded C.
Old Apr 12, 2009 | 02:44 PM
GrtDanes's Avatar
GrtDanes
I replaced both fuseable links,still nothing??Power to starter and alt,but nothing else??
Old Apr 12, 2009 | 04:09 PM
GrtDanes's Avatar
GrtDanes
Thanks every1.Got her going.Found a connection that wasnt hook up also thanks to Twin Turbo.
Old Apr 13, 2009 | 02:34 PM
Eddie 70's Avatar
Eddie 70
What connection was left undone? Just curious.
Old Apr 14, 2009 | 11:14 PM
GrtDanes's Avatar
GrtDanes
Its a 6 prong connector by the heater and the gauges are plugged in to it.Its a white or clear coloured connectot that rund off starter then goes threw firewall.
To Electrical help?What did I do now??
