Thermostat problem
1. Radiator Cap: Removed it for the first time in a long time yesterday, and it was old, maybe even original. Thinking maybe it's not creating a tight seal anymore??
2. Drill current thermostat after testing to ensure it's functional. If I find it still works, I'm going to drill the hole in that first to see if it will bleed the line free of air and eliminate the spikes in temp.
3. thermostat: Buy new thermostat. If that alone doesn't work, I'll vent it with a drill hole to bleed the air from the line.
Mine runs around 180-195 degrees and then suddenly spikes to 210-220, then immediately drops back down. The spikes are freaking me out, though. It hasn't run that hot since I first drove it home the day I bought it (last August). It was 75 degrees this morning and the car spiked to around 210, which is way above normal for my car. Any time it hits 200 I get nervous. When it spiked, I was in the middle of an expressway... not idling or sitting for a prolonged period. It just jumped up as I was driving around 40mph and then dipped back down and stayed at 185 degrees. I got it to work and my buddy came to take a look, and the line that dumps from the radiator into the block was soft, as if there were no water or pressure. We started it up and it idled at 185 degrees in the parking lot for 15 minutes with no issues.
Car info: Small block GM 350 Crate motor, 1968 convertible, no A/C, manual transmission, headers, just installed the heater-core shutoff hose to get rid of cabin heart. The issue occurs with the valve open or closed to the heater core, so I don't think that's the cause.
WHEN IT'S FULL, REINSTALL THE THEMOSTAT AND TOP OFF AT THE RADIATOR IF NEEDED.
THIS IS DONE IN ADDITION TO THE DRILLED THERMOSTAT.
WORKS EVERY TIME FOR ME.
BILL SR
100%
