Mandrel bent exhaust pipes?
Old Apr 13, 2009 | 06:35 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Default Mandrel bent exhaust pipes?
I'm looking for a source for 2 1/2 inch (or 2 3/4") mandrel bent exhaust pipes to run from the transmission cross member back to the mufflers. Unfortunately, all the different pipes I've seen for MANY years all have had a reduced cross section at each bend, and were oval (squashed) in cross section from the cross member to just past the differential.
So, do any of the vendors on-line have mandrel bent pipes with a round cross section?
Does ANYONE have a source, or know who makes them?
Thanks!
Old Apr 13, 2009 | 06:39 PM
Solid LT1's Avatar
Solid LT1
Magnaflow and Stainlessworks have full 2.5" diamter systems with no reduced radius bends in them. Stainlessworks would probably be your best source for the pipes alone.
Old Apr 13, 2009 | 06:51 PM
C3BB4SPD's Avatar
C3BB4SPD
You didn't say if you were looking for aluminized or stainless steel?
Summit has this cat-back aluminized system from DynoMax that's mandrel bent. But I don't know if they just sell the pipes or not though.
http://store.summitracing.com/egnsea...00491#footnote
Old Apr 13, 2009 | 07:10 PM
JOEY CARTEE's Avatar
JOEY CARTEE
Thanks!
Hey larry, I used Allens on my car and it has some cross section loss at the bends but im relly impressed with there exhausts out of the box... but no flatting on the pipe...Joey
To Mandrel bent exhaust pipes?
