trailing arm wheel brg.replacement
Old Apr 13, 2009 | 07:28 PM
MICKY B's Avatar
MICKY B
Default trailing arm wheel brg.replacement
i know there must be many threads on this subject ,could someone please send me in the right direction ?
Old Apr 13, 2009 | 07:34 PM
Gordonm's Avatar
Gordonm
Go to Gary GTR1999 here on the forum. He does top quality work or will work with you on doing it yourself. This is not a job for the weekend mechanic. It takes special tools and presses and know how.
Duke94's Avatar
Duke94
Here's a web site I saved that has the procedure.
Gary
http://www.corvetteforum.net/c3/zwed...railingarm.htm
Old Apr 13, 2009 | 08:27 PM
Alex/plus's Avatar
Alex/plus
Thanks Gary for pointing me to that article.
I'm set to do this rebuild in June so now I can start assembling the make-shift tools i'll need.
Old Apr 14, 2009 | 07:14 PM
MICKY B's Avatar
MICKY B
Default thanks guys
thanks for the info,maybe i should get professionally done ! mike
Old Apr 14, 2009 | 07:27 PM
Duke94's Avatar
Duke94
Look at it as a challenge. It's all just mechanical stuff, nothing real complicated. You need a few "special" tools but the procedures are well documented in the GM service manuals and on the internet.
Gary
Old Apr 14, 2009 | 08:44 PM
kdf1986's Avatar
kdf1986
I replaced the left side trailing arm on my 75 in December. I bought a new unit completely assembled and sent my old one back for a core charge. While I missed out on the fun of doing all the replacement, preload, checks, etc. I did save a lot of time by taking the old one out, and putting the new one in.
For me the time issue was the important factor. By doing this a couple of hours on the weekend would have taken me a couple of months. By taking the entire TA assembly out and replacing it took only a couple of weekends.
KDF
To trailing arm wheel brg.replacement
