Higher Tripower airfilter
Old Apr 14, 2009 | 02:08 PM
WESCH's Avatar
WESCH
Default Higher Tripower airfilter
Hi
Because I have a L88 hood on my 68 tripower, I thought about the very limited space above the carbs to the lid of the airfilter restricting proper airflow a lot. So I decided to lift the lid.
I used a second filter metal grill and cut my proper filter foam, now exactly double as high as original.
Everything is returnable to original without any damage.
Next I will lift the ignition shielding up a touch to accept the HEI distributor.
Rgds. Günther
I know I'm missing the hose from the filter to the L/H head for crankcase ventilation, it will be on my next order list to get writ of the head filter mushroom.
Old Apr 14, 2009 | 06:47 PM
Wrencher's Avatar
Wrencher
That works. I run the K&N unit in mine, and I suppose you could stack those as well, but it wouldn't look as clean.
Hans
Old Apr 15, 2009 | 04:04 AM
WESCH's Avatar
WESCH
Hi
I was also thinking about the K&N, but is is also as low as the original one.
I wasn`t concerned about the air mass being reduced through the filter, but of the very low lid sitting on top of the carbs.
I read a article where this was checked and if I remember right, it is the front carb that suffers most.
With some cutting , the K&Ns could be fitted together in such a way, that it would look nice, I guess.
Might be worse a try.
I will see how this foam thing holds up and if not, try the K&N way.
Rgds. Günther
To Higher Tripower airfilter
