What is the correct factory transmission gear (color) for an M20/3.55 gear combo?
TIA,
Mike
no such thing as a correct gear.....it depends on the drive gear in the tranny and it could have come with two different ones...t.here are several ways to calculate your correct speed..then if the speedo is too slow, go down teeth on the driven gear if too fast then go up in teeth...parts books will list the so called correct gear but many times they are in correct......
What determined which drive gear? I assume rear gear ratio? I would think the 3.70 and numerically higher rears would get a different gear?
Yes, the rear axle ratio normally determined which drive gear would be used. Lower axles usually got the smaller drive gear with the larger driven gears, and higher axle ratios were just the opposite but there were exceptions. The 3.55 is right in the middle and could go either way so need to find out what drive gear is in there now, and your driven gear will tell you that. Going up 2 or 3 teeth should fix you up provided no other problems.
Thanks guys, that's the info I was looking for. It's an L46 with the optional 3.55 rear. I'll post what I find on the driven gear.
