automatic shift handle adjustment
Old Apr 15, 2009 | 06:15 PM
mint79's Avatar
mint79
Default automatic shift handle adjustment
Onto a project that has been on hold, now that i have a new shift shaft seal and no more leaks, how would i go about lining up the shift lever with a p-r-n-1-2-3 on the console, indicator is off about half
a number. if you put it in D you are in 2nd. D is lined up with N and so on and so forth, thanks guys. Oh-it is a 1979 turbo 350!!
Old Apr 15, 2009 | 09:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ok. . .I'll bite on this one.
The shifter has a lever on it that slides in the indicator (number 5). This lever can be adjusted.
1) Put the shifter in neutral.
2) Take the screw loose (number 4) holding the link and move it until the indicator shows neutral.
3) Tighten the link screw to about 3 lbs of torque.
Old Apr 15, 2009 | 09:57 PM
mint79's Avatar
mint79
Thanks-will remove the console side panel and try it in the a.m.
Old Apr 17, 2009 | 01:52 PM
mint79's Avatar
mint79
Thank Willcox corvette, everything lines up nicely, by the way, i purchased 2 door panels from you a couple of years ago, very happy with the price and quality!! Thanks again
Old Apr 17, 2009 | 08:44 PM
0Willcox Corvette
Former Vendor
Thank you for the business!
Willcox Inc.
To automatic shift handle adjustment
