Brake Booster Questions HELP!!!
restore the boosters full vacuum supply and see if that eliminates the problem and go from there
After that, I would try this for bleeding:
Bleed the brakes furthest to closest.
Bleed the brakes again closest to furthest.
It's possible you somehow had air that didn't make it out, or your MC went dry, and you re-introduced air into the system accidentally.
Set your Motive power bleeder to 15PSIG.
Keep the Motive tank dry
Bleed one caliper at a time and then refill the MC after each bleeder session so you dont go dry.
Be sure that on the rear calipers, you do the inner bleeder first, then outer bleeder.
Youll get it.
Then when your done, and your foot still goes too far to the floor
, sheetcan the vacuum boost and get a hydroboost set-up. You'll be raving how this is one of the best things you did to your car. Only 1 inch of travel and then just foot-toe pressure applied from there will get you back to 0MPH quite quickly.
