Rear trailing arm shims
Old Apr 17, 2009 | 04:20 PM
mcolvin's Avatar
mcolvin
6th Gear
Default Rear trailing arm shims
How do you keep the rear trailing arm shims from falling out?
Old Apr 17, 2009 | 04:28 PM
wcsinx's Avatar
wcsinx
There's a hole in the end of each shim. After pounding them all in, you rotate them downwards into the pocket until the holes in the shim ends line up with a little hole going through both sides of the t-arm pocket. Secure the works with a big cotter pin going through everything.
