1978, tach inoperable
Is it no doubt a "board" issue and if so is replacement of the whole assembly the only option ?
Cheers and thanks for any and all replies.
http://www.zip-corvette.com/Zip/prod...4E2DE75F6D7012
Here's a how-to article
http://www.corvettemagazine.com/2005.../tach-lead.asp
Make sure you have 12 volts to the tach
Make sure you verify the Tach ground
Make sure you verify continuity from the tach wire on the connector to the distributor.
Inline on our car there is a tach filter, this filter is held in place with one bolt to the intake manifold. If you do not have continuity from the connector to the distributor, un-plug the tach filter from the system. See if you have continuity from the dash connector to the plug where the filter plugged in. If you do have continuity to this connector then plug this connector to the “tach” connector on the distributor bypassing the tach filter. Now plug in the connector and see if it works. If this works inspect the filter to see if the wire is broke at the capacitor, if it is you can try to place a drop of solder in the capacitor to get the filter working again. This can be hit or miss. If the filter is bad we do carry a replacement style on the web site.
Testing without the filter will not hurt the tach in any way shape or form. If the tach works when you do this you need to replace or repair the filter.
If you have power at the tach and a verified ground with good continuity from the distributor to the tach and it is not working you have a board problem more than likely. If you want to test the tach by doing a hard wire test the help page listed below will tell you exactly how to do this. It is the same test we suggest you do before installing a tach with a new board in the car just to verify the tach is working properly.
I have a page on my web site that will help you in this repair: (and has the hard wire test). http://willcoxcorvette.com/repairand...lp.php?hID=252
I also have a page on the site on how to remove the tach from the car at this link:
http://willcoxcorvette.com/repairand...lp.php?hID=146
Should you need the tach board, I have them listed in the Forum Special section under this link and these boards are pre-tested and calibrated before we send them out. http://willcoxcorvette.com/advanced_...&keywords=tach If you enter the current sale discount code on check out, you will receive an additional discount on this item too. This sale code is DRWH3A and must be entered when checking out on the site.
On your printed circuit, the top wire on the tach side is your ground, the second wire down is the signal wire from the distributor and the third wire from the top is the power wire. Not this is if you were looking at the back of the tach with it sitting on our lap. So the wires in the car if you were facing the connector when un-plugged go to the passenger side top wire. This is the tach ground. The passenger side wire second from the top is the square signal wire from the distributor, and the third one down on the passenger side of the plug is the 12 volts to the tach.
I hope this make sense. . .
Now pull the tach, test your wires and if this is not enough info either post again or email me direct at Willcoxcustomerservice@willcoxcorvette.c om.
Willcox Inc.
Here is the printed circuit board for the tach and speedo showing the wires above.
