Working with fiberglass
Like best way to repair a hole in the panel?
How to fix that 'star' affect?
How to pick what type of fabric to use (lord I didn't know there was more then one choice).
What type of filler to use to get minor dings resolved?
etc . .
I am not near ready to work on body yet (http://rockymtninfo.org/ABetterVet.html) , but I would like to practice on other projects first.
Ecklers has a couple of DVDs, can't say if they are any good or not. There is also a book called The Fiberglass Construction Handbook that you might look over, not sure if its worth buying for what you need to do. You can also check out http://www.glas-ra.com/ and http://www.westsystem.com/ss/how-to-use/
The resin is different than that of press molded fiberglass and requires much attention to how clean the panel is prior to lanimating. I have been doing restoration for over 20 years and have found that wiping the prepped area with acetone provides a very clean residue free area for my repair products that I use. Remember it is always that 1/1,000,000 " of residue that can inhibit a product from adhering correctly.
Never use the clotch fabric on the top surface. but it is great as a final layer on the underside for much great linear strength than the matt.
Air bubbles are a major concern and much care should be given when laninating to prevent air bubbles by using special rollers designed for fiberglass laminating or the use of a paint brush with about half of the length of the bristles cut off to strengthen them to aid in forcing the air out.
Using West products is great. I use this product in repairing carbon fiber funny car bodies and it works great. Just do not mix up excessive amounts of the product because depending on the temperature at the time, the product inside your mixing bucket will cure very rapidly if there is a large volume of it in the container. I usually mix 3-4 ounces at a time and keep mixing instead of mixing a quart and knowing that it will take me some time to get it applied. On second it is liquid the next second it is hard. Been there, done that. Just wasted good material.
I hoped this helped , if you need more info, contact me.
As for fillind in minor gouges , (not cracks) the use of Fiberglass/evercoat Vette panel adhesive/ filler is awesome. I have used it for years with NEVER a problem. It is awesome filler and gets very hard. It has some tricks of its own if you need to know.
Also taper all of your repairs, holes , cracks etc. Do not leave the prepped area just squared off, if you dont....you will have a problem.
"DUB"
