Ground strap
Old Apr 20, 2009 | 10:42 PM
78 Shark's Avatar
78 Shark
6th Gear
Default Ground strap
I have a 78 and I cant remember where the ground strap goes comming from the outside ac/heater box stud bolt? I think it goes to the back of the head but not sure. Any help Thanks 78 Shark
Old Apr 21, 2009 | 06:37 PM
78 Shark's Avatar
78 Shark
6th Gear
Default Please Help
Can anyone look under their hood and tell me where the ground strap is supposed to be connect to the engine. The one end comes from the ac/heater box. 78 Shark
Old Apr 21, 2009 | 07:00 PM
Duke94's Avatar
Duke94
The AC on my 78' is long gone, but I had a few pics of it. There is a compressor ground wire that connects to one of the compressor mounting bolts. The bolt that is loose in this pic. Is that the one you mean?
Gary
Old Apr 21, 2009 | 10:19 PM
aussiejohn's Avatar
aussiejohn
Default Wiring ground
Duke,
I think he means the one near the firewall that is factory fitted under one of the starter motor bolts. It should have a hole (eyelet???) in the soldered on end that is about 10mm in diameter, big enough for a starter motor bolt to go through.
I've got that problem now as the gear reduction mini starter I fitted has countersunk Allen head bolts and the earth wire will not fit there. A transmission to engine block bolt would be OK, but I think that those bolts are 7/16" and the hole in the earth wire would have to be enlarged.
Main thing to do though, is to make sure that the earth wire is grounded to the chassis, even if that means bolting it to the engine first. Then make sure that the engine to chassis earth wire is tight and has good metal to metal contact at each end.
Regards from Down Under
aussiejohn
4 months to go
Old Apr 21, 2009 | 10:28 PM
78 Shark's Avatar
78 Shark
6th Gear
no, I was refering to the evaportor box on the firewall, I had a strap comming off the stud and going to the valve cover and could not find where it was originally. Thanks for the pic though 78 Shark
Old Apr 21, 2009 | 11:00 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
This?
Old Apr 22, 2009 | 06:03 AM
78 Shark's Avatar
78 Shark
6th Gear
Yes KapsSA, that looks like it. When I purchased my car the distributor cover was missing so I guess they previous owner moved the ground strap to the outside ac/heater box going then going to the valve cover. Where does you the strap go? It looks as if it go to the intake bolt. Thanks for the pic and support. 78 Shark
Old Apr 22, 2009 | 10:07 AM
KapsSA's Avatar
KapsSA
Goes to the valve cover bolt. It's only purpose is to ground the shield. Don't see why they'd hook it up elsewhere.
To Ground strap
