Help with '77 power windows
Old Feb 1, 2002 | 09:13 PM
Ryan77's Avatar
Ryan77
Default Help with '77 power windows
The power windows stopped working in my '77 out of the blue. Any suggestions on what the problem could be? Already replaced the blown fuse I found but didn't help.
Old Feb 1, 2002 | 11:15 PM
Dalannex's Avatar
Dalannex
Default Re: Help with '77 power windows (Ryan77)
I'm afraid I have bad news. You need to tear the door apart. I would say that more than likely the motor is shot. It could be a shorted switch or something broke on the regulator binding it up, but if it blows the fuse, it's probably a bad motor. Either way, tearing into the doors on these cars isn't fun. Good luck. :cheers:
Old Feb 1, 2002 | 11:25 PM
Aaron76's Avatar
Aaron76
did both of your windows quit at the same time if so it is most likely the power window relay which is under the console.
make sure to check the wires in the door jam they can get caught and pinched.
Old Feb 2, 2002 | 11:21 AM
Ganey's Avatar
Ganey
Default Re: Help with '77 power windows (Aaron76)
Since you said windows, look at circuit breaker & connections. The basic system is very reliable!
:cool:
Old Feb 2, 2002 | 04:49 PM
paso's Avatar
paso
Welcome ryan I hope you plan to add your car to the 77 registry see link below
Old Feb 2, 2002 | 07:55 PM
Ryan77's Avatar
Ryan77
Yes, both windows did quit at the same time. Thanks for the suggestions, I'll give them a try and see what happens.
To Help with '77 power windows
