Default Position for Vacuum Heat Riser Valve
Old Apr 22, 2009 | 12:29 AM
Slalom4me's Avatar
Slalom4me
Default Default Position for Vacuum Heat Riser Valve
Is the default position (no vacuum) for a 70's-80's vacuum-actuated
heat riser valve open or closed?
Thanks,
Ken R.
Old Apr 22, 2009 | 12:46 AM
TimAT's Avatar
TimAT
Open= as the vacuum is applied it pulls the rod and closes the valve
Old Apr 22, 2009 | 01:15 AM
Slalom4me's Avatar
Slalom4me
Defaulting to open is a safe design.
Thank you.
Old May 16, 2009 | 11:40 PM
RobertHuggins's Avatar
RobertHuggins
Cruising
So the vacuum source for the heat riser PULLS vacuum when the car is cold and STOPS vacuum when the car warms up?
Not only that; but it has to release the vacuum already applied to allow the heat riser to open?
To Default Position for Vacuum Heat Riser Valve
