Wanted: official GM specifications of the 454 LS-7
From what I've read, the reasons for killing the LS7 production option at that time include: GM's policy of deproliferation of engine options across the board and the nascent push for fuel efficiency, but the one that strikes me as most likely is the hoo-hah created around that time by daily press jounalists about "muscle cars" in general panicking GM management which, by then, was essentially a cabal of corporate accountants anyway.
Interesting that GM would publish that page. The horsepower specs are all 460- which rumor at the time had it being the LS-7, yet that engine never made it to a production car. And same with the compression they're showing 11.25:1 Everything else I've seen points to the LS-7 being 12.25:1.
Don't get me wrong, I'm not questioning the validity of the document, I just find it interesting..
I've seen them listed as 450 HP but it was the same ruse they used for the L88.
cc
The entire March 70 issue of Chevrolet Service News, apart from 2 sections on the back page, is devoted to the 1970 Corvette, and those 2 non-specific sections are "Servicing Propeller Shaft Front Slip Yokes" & "Auxiliary Battery Option - 1969-70 Camper Equipped Trucks".
The engine specs page is from Section 6.
Entirely different for L-88, HP was rated lower to keep the clueless (like .........) from ordering the highest HP engine.
The LS-7 was basically a replacement for the L-88.
450hp output is no better than the L89s in 1967 which were immediately re-labeled 435.
The most you give up to exhaust is 15-20 hp.
cc
A high power BB loses a lot more than that w/ manifolds instead of headers! The nos. you have are too high.
OTC crate "LS-7" 12 C/R on dyno w/ headers
HP 489 @ 6000
TQ 481 @ 4000
HP 489 @ 6000
TQ 481 @ 4000
The guy modified the crate engine.
cc
..Noticed that two of the postings alluded to the LS6 or LS7 being gas gusslers.
I built a piece part L88 with the only modifications being that I had the piston domes milled down to lower compression from 12.5:1 to ~11.5:1The engine delivered good gas mileage numbers. However, I did have a 3.08:1 rear end diff ratio. I could drive to Las Vegas on one tank of gas, and have some left over. owever, the L88 cam and 3.08 made the car difficult to drive on the street since it had such low torque at low engine rpms. After coming for a stop at an intersection, it took a lot of clutch slip to get the car rolling. This streetability problem was solved with a Richmond 5 speed (then sold as a Doug Nash 4+1).
#33
I have had the (now hydraulic) clutch replaced to McLeod Street/Strip and that's quite heavy underfoot. Yes, launching is a bit wild and the cam doesn't like city traffic, but on the highway it's a great car to drive.
I should add that cooling is not an issue. It still has the original GM clutch fan and shroud, albeit with 7 blades (no aircon).
#35
I had problems with cooling over 70 MPH- got the year of manufacture plates which let me remove the front plate and bracket, and no more cooling problems. The factory L-88 radiator was installed in '71 with a piece/part shroud.
#37
I was on a Club run on Sydney's the hottest February day on record when it hit 44C (111F) in the shade, and the Vette just sat on 195 degrees all day, even when idling in the traffic. The other guys on the run with me could not believe it. In fact, a lot of guys, with small blocks, avoided the run when they heard the predicted temperature simply because they feared a boil over.
Plates-wise, I have the only type of NSW plate that will fit without bending:
#38
Dont mean to hijack your thread gtc131 but like you I have tried tracking down the original factory specs for the crate LS7 with little luck. Even in this thread there seems to be inconsistant results, perhaps due to confusion between the two engines, the crate engine and the proposed option engine.
BTW nice to see another LS7 owner down this way.
Cheers
Tony
Cheers
Tony
#39
Chevy put the 850 cfm carb on the L-88's. FWIW, I've had everything on mine from a 650 to a 2x4 setup that worked out just over 1200 cfm. The 650 was bad to the bone off of a stoplight, but ran out of air before 5000- labored hard to make 6500. 750 wasn't too bad- lost some low end and gained it back on top. the 850 is good - kind of a balance between not having low end torque and a really good top end. The 2x4's were unreal- great down low and would really come alive and pull hard.
I don't think 850 is too much for what you're running. Mine works real well overall. Maybe you need to work out some jetting or power valve issues?
Your front plate looks the same as what we run here. I never had any problems at low speed, just at hiway speed. And it wasn't anything bad- it'd just get up to 210.
#40
Pmccooey (05-10-2017)
