Turn signals
Old Apr 24, 2009 | 12:39 PM
Rambo819's Avatar
Rambo819
6th Gear
Default Turn signals
Hi, I have a 1979 L-82 and the turn signals have stopped working. The first time out they worked intermittently but now they don't work at all. The weird thing is the hazards still work perfect. I have sprayed contact cleaner in the actual switch and that didn't help. Any ideas?
Thanks in advance!
Ryan
Old Apr 24, 2009 | 12:47 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Did you try to replace the turn signal flasher which is located under passenger side of dash?
Old Apr 24, 2009 | 01:12 PM
Rambo819's Avatar
Rambo819
6th Gear
No I didn't is there one flasher for both the hazards and turn signals? Also, is there a way to see if its good?
Old Apr 24, 2009 | 01:17 PM
Rambo819's Avatar
Rambo819
6th Gear
Also whats the flasher look like? Never had to deal with one before
Old Apr 24, 2009 | 01:54 PM
mdj21's Avatar
mdj21
There are separate flashers for the hazards and for the turn signals. Turn signal flasher is behind the passenger’s side dash and can be reached from underneath. Hazard flasher is on the fuse panel by the drivers left foot. They both look identical. They are cylindrical about 1 1/8" in diameter and about 1" long with two spade terminals on one end.
Hope this helps,
Mike.
Old Apr 24, 2009 | 06:51 PM
Rambo819's Avatar
Rambo819
6th Gear
Yea, I found the fuse panel by the drivers left foot, switched the two flashers and the turn signals now work so that was the problem. Just have to pick a new flasher for the hazards now.
Thanks for all the help!!
Ryan
To Turn signals
