Hi,
In the process of fitting VBandP Smart Struts to my '74.
If you've done this yourself you will know what I'm talking about - otherwise you may not.
The Cam bolts on the standard struts are in horizontal slots to move the rods in and out thus adjusting the camber.
The new ones have vertical slots and the camber is adjusted by lengthening the rods (like the toe-in on the front).
The assembly leaflet says start with the cam bolts in the middle position and adjust the length of the rods to adjust the camber. All OK so far.
So what the hell are the cam bolts for other than changing the angle between the rod and half shaft. Assuming that is what it is - what is it supposed to be ??
Hi,
Cheers for listening.
Jeremy.
That is exactly what the cam bolts are for - changing the angle between the rod and the half-shaft. The relationship between the rod and shaft affects the amount of camber change as the tire moves up and down. From what I've read the lower in the slot you position the inner end of the strut rod the less the camber angle will change. I have to look this up again because I replaced the entire suspension and it hasn't been aligned yet.
Try looking on the VB&P website. There might be more information on strut rod adjustment there.
The struts I got had 4 plates with each rod. Only needed 2 on each rod at the differential bracket. That effectively locks the inboard end in the center of the bracket. they also came with new bolts. I didn't get the smart strut package, just replaced the struts with some HD units.
I was a little confused at first when I went to install the SmartStrut package. They included both the plates and the cam bolts. You use the plates if you are using the stock differential bracket and the cam bolts if you are using the VB&P differential bracket.
Interesting. I thought the idea of the smart struts was to lower the mounting point of the inboard end of the rods and then make your camber adjustment with the rod. If you don't eliminate the cam bolts, it seems to me like you'd get a redundant adjustment point, or at the least an adjustment point with a lot of travel. You'd get all the adjustment available from the cam bolt, PLUS the adjustment afforded by the strut rod ends.
TimAT
Thanks for the responses Guys,
The slot for the CAM is vertical in the VBandP mount such that the adjustment of the CAM doesn't effect the camber (it's all done with the rod ends as you say).
So I guess that the vertical adjustment does something weird when cornering I must say the geometry is quite unclear to me.
I guess I'll go with the mid point and forget about it !?!
TimAT
Jeremy.
You probably should have just bought a pair of stock strut rods and used the stock bracket. Sounds like you wasted some $ buying the SmartStruts.
If you compare the brackets, does the smart strut kit bracket allow the inboard end of the rod to set lower?
Yes. The stock bracket has a horizontal slot and the SmartStrut has a vertical slot. If you haven't installed a SmartStrut why are you replying to this thread? The OP was asking for advice from those who have installed SmartStruts. From you comments it seems that you have not.
That is correct- I elected to NOT go with the smart struts for my car. But I DID do a whole lot of research before I made my decision. Based on the movement of the struts setting them lower will give them extra travel. Using the factory bracket, with the slots running horizontally, the cam bolts are where the adjustment is- Setting the struts lower, but maintaining the same center point there's really no need for the cam other than to either put the rods in the stock location OR set them lower. The center is where it is- and camber is adjusted by the rods.
The basic idea is to get the tires to stay FLAT on the ground during heavy cornering. And having the added up/down adjustment of the struts is a way to do that.
Just went thru the same confusion installing smart struts on my #73. They told me to turn the cams to the lowest position. That made sense as it creates close to a parrallelagram with the driveshafts. i believe that it will result in minimal change to camber as the suspension travels thru it's stroke. I also thought it makes no sense to keep the cams, as they are a redundent adjustment. I cut some 1/8" square plates with a hole in each at the lowest cam position to replace the cams, then used grade 8 bolts and nylock nuts to secure the rod ends.
Tells you to initially adjust cam at center. Then do an alignment. The whole purpose of this upgrade is to maintain the wheel/tire camber through all ranges.
I have installed the complete smart struts with heym joints in these days.
I used the square washers so the rod is placed in the middle of the vertical slot.
I have a pretty high ride height due to ground clearance and the smart struts works fine in this setting to reduce the excessive camber gain.
if the ride height is low, the best solution seems to be instead to use just the rods and not the VB&P differential bracket.
the car handles great now but I can't address the good results just to the smart struts because at the same time I have replaced also the trailing arms bushings ( were shot) and went for Bilstein sport in place of HD
Thanks again guys. It's neat that everyone is doing different things
I've read the instructions that say fit the cam in the centre poisition and then do the alignment. If yu do that it ends up in the middle since the camber is done with the rods - Hence the question.
ktmdon : lowest position - was that advice from VBandP ?
If so - why the hell don't the instructions say that
Yes, this was the advice over the phone. I then mocked up top, middle and lowest cam position (with their bracket) and the lowest position was the closest to placing the struts parrallel to the drive shaft, so it made sense to me. I also asked why they continue to use the cams and did not recieve a clear answer.
I had the exact same question when I received my SmartStrut kit. My kit only had the square washers and I noticed from looking at a LOT of CF rearends, that many used the square washers and the rest used the camber bolts. When I asked Dan at VanSteel, he suggested using the camber bolt. You set it to make the struts run parallel with the half-shafts. So set the camber bolt first to get parallel, then adjust the camber with your adjustable struts. Once I got it in there and played with a little, it made sense. Mine are set so the little hole in the camber bolt/eccentric washer is on top, which places the strut in the lowest position.
From: Graceland in a Not Correctly Restored Stingray
The vertical slots afford adjustment to the camber curve rather than to static camber. This is the rate at which [negative] camber is gained as the rear suspension travels into bump or squat. The higher is your priority to straight line acceleration (i.e.: drag racing) vs. that during corner exit, the closer to parallel you want to place your camber struts with the half-shafts. Tho to a lesser extent, the same is somewhat true for putting down the power exiting corners the more power you have, or the wider are your rear tires.
If drag racing isn't a larger priority than handling, I strongly suggest that you move the inner adjustment to the top of the slots. Unless you intend on performing scientific, instrumented back-to-back testing to find a better setting, this position should suffice for most non-strip applications. My $.02
TSW
