head gasket
Old Apr 26, 2009 | 09:21 AM
Tina69's Avatar
Tina69
Default head gasket
Curious as to what some of you have used for a head gasket who have a 350 sb .030 over, 64cc aluminum heads, flat top piston with valve relief.
Old Apr 26, 2009 | 10:47 AM
tsw71's Avatar
tsw71
I went with the Felpro FPP-1094. It's the rubber coated steel shim type. It's advertized as .015" thick, but if I remember right, it's actually .017" with the coating. With the pistons down .020" in the hole, you'll end up about 10.5:1. with .037" quench. Has your block been decked? You should determing deck height first.
