Motor mount source??
Old Apr 28, 2009 | 12:46 PM
newcastlegreg's Avatar
newcastlegreg
Default Motor mount source??
I am doing a frame off on a 67 BB. I seem to be having trouble finding suitable motor mounts. I got an expensive set from the chev dealer that sold me the crate motor-but I would have to bend them out about an eighth inch to fit over frame. Where can I get a quality set ?? Height is very critical as I am converting to tremac- also the safety style would also be good-thanks-Greg
Old Apr 28, 2009 | 07:18 PM
markdtn's Avatar
markdtn
'67 is a C3 so you are really in the wrong forum. But the frame is basically the same. If you don't care about original you can try NAPA. Most of the catalogs also sell motor mounts.
Old Apr 28, 2009 | 07:49 PM
newcastlegreg
Default same car
The c2 and c3 are mechanically the same automoblile in case you did not know... so I see nothing wrong with sharing technical information. There are also a lot more c3 than c2's so the c3 forum has a wealth of tech info
Old Apr 30, 2009 | 08:31 PM
markdtn's Avatar
markdtn
Originally Posted by newcastlegreg
The c2 and c3 are mechanically the same automoblile in case you did not know....
I said that. The 69 up motor mounts are the interlocking safety type and should bolt right onto your frame.
Old Apr 30, 2009 | 09:07 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I carry the original mounts for the 67 if that is what you need. Here is the link: http://willcoxcorvette.com/product_i...oducts_id=6204
To Motor mount source??
