Early 79 power antenna.....Outer trim???
Old Feb 2, 2002 | 11:54 PM
BADCAIMAN's Avatar
BADCAIMAN
Default Early 79 power antenna.....Outer trim???
I was putting the car back together..and am not sure if I am missing a trim of some kind that goes around the opening in the body for the power antenna....I have the chrome threaded insulated bezel that locks it in place..But i believe there should be something else between the body and the chrome..Due to the fact that the indentation on the body is a lot larger than the bezel...Anyone have any idea or pictures
Old Feb 3, 2002 | 01:43 PM
Shark79's Avatar
Shark79
Default Re: Early 79 power antenna.....Outer trim??? (BADCAIMAN)
You've got mail, I hope this helps.
Kip
Old Feb 3, 2002 | 03:22 PM
BADCAIMAN's Avatar
BADCAIMAN
Default Re: Early 79 power antenna.....Outer trim??? (Shark79)
Thanks Kip..Got the picture I must have a replacement..My set up sits flush with the body panel..I might have to buy the correct antenna..But Thanks again
To Early 79 power antenna.....Outer trim???
