engine running cold imo
Old Apr 28, 2009 | 08:17 PM
kapla74's Avatar
kapla74
Default engine running cold imo
My engine always runs in a quarter of the gauge in the middle between the 0 and the middle of the gauge..is that ok? I have the stock tstat for that engine and year ... but my radiator was rebuilt here with a new core addind more water passages than the original...I have the clutch fan.. you think I should get a new tsat with a higher rate? its a 73 sm l-82 manual
Old Apr 28, 2009 | 08:26 PM
maddmickey's Avatar
maddmickey
Your t-stat should keep the engine at whatever its rated for(180?). I would suspect the guage. I would use a raytec or similar temp gun and see what the temp is on the thermostat housing, fully warmed up.
Old Apr 28, 2009 | 08:58 PM
TimAT's Avatar
TimAT
I'll bet on the gauge too- check it. You can get one of those infra-red thermometers or get a meat thermometer- Take the radiator cap off and stick the probe in the coolant. See how close that and the gauge are. Don't use the meat thermometer on anything you want to eat- antifreeze is NOT good for you.
Old Apr 28, 2009 | 08:59 PM
wer2xu's Avatar
wer2xu
But it tastes really sweet!
Old Apr 28, 2009 | 09:38 PM
kapla74's Avatar
kapla74
I have this tester with a t probe so i will check for that...is it safe to remove the radiator cap while the engine is running?
Old Apr 28, 2009 | 11:18 PM
TimAT's Avatar
TimAT
remove the radiator cap with the engine COLD then start it and let it arm up. No danger of getting burned that way. Better safe than sorry in this case.
Old Apr 28, 2009 | 11:19 PM
TimAT's Avatar
TimAT
But it's real tough on the kidneys.
Old Apr 29, 2009 | 08:00 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
That area on your gauge is actually the 180 degree mark. That is where my 68 runs all the time. You can check your temps with an IR gun just to confirm.
Assuming your gauge is the same or similar to my 68 BB, the far left is 100, then there is a line with no designation about 1/4 of the way over (that's 180) and the next line is 210 which is at about 12 o'clock.
Old Apr 29, 2009 | 08:16 AM
joewill's Avatar
joewill
your gauge and your temperature sending unit have to be a mated pair, with no extra resistance built into the system. many times this is not the case.. I use it only to tell me if I am overheating.. other than that I don't trust what the gauge says. your only real way to measure how hot you are running is to measure the coolant temp itself..
Old Apr 29, 2009 | 08:26 AM
Ganey's Avatar
Ganey
Start cold w/ cap off & thermometer in place, then when the thermostat opens look at the gauge. Thermostat can be tested suspended in a pan of water on stove w/ thermometer.
"Middle" 1/4 line is 180 on mine top marked 200.
To engine running cold imo
