I need some engine basics. I was wondering if someone can provide some basics on our SBC engines. I have noticed (perhaps mistaken) that features that enhance horsepower like 2.02 intake valves, high-flow intake manifolds, large tubular headers, 2.5" exhaust, etc. seem to make these gains at the expense of torque. What confuses me is the recommendation by some that there needs to be some backpressure from the exhaust and airflow restriction in the intake manifold (i.e. dual plane) to keep torque values higher. From the discussions, it would seem that open exhaust would actually decrease torque. Is this correct or do high-HP changes just move the peak torque to a higher RPM? In my situation (autocross), top-end performance is not necessary but acceleration in important. So, I suspect I need a good low gear and a broad or low torque band. Thanks for the education.
If you just start throwing parts at an engine (often times based upon magazine stories), they you often end up with what you deserve. An understanding of how all these systems operate in isolation, then as part of a package is necessary to come to the right choices. You don't have to be an expert, but you should at least do some investigating on your own and take no one's word for anything. Research and verify.
Your posit on intake and exhaust is a great example. On the intake, you need adequate velocity for the carburetor to shear and atomize fuel and avoid plating on the intake. It's not a matter of restriction. It's a matter of design and you can have excellent throttle and very low restriction if you do it right. On the exhaust, you need adequate velocity to scavange the cylinders. You'd like to have no backpressure at all. Going to too big of a pipe creates more surface area which gives heat a bigger escape path (heat is energy, which you need to maintain velocity) and the bigger pipe creates more gas friction due to the increase in boundry and surface area. It's easy to think a reduction in performance from a larger pipe means you need backpressure, but that's not quite it. It's still a design issue.
An engine builder will take into consideration the parts individually and determine how they will harmonize with the goals. Some of the best engines don't have the most sophisticated parts because the builder understand how this all comes together and pretty much avoids giving magazine stories too much weight.
Thanks. This helps me understand some of the dyno data that I have seen. It sounds like you have some experience with fluid dynamics as it pertains to engine performance.
