Window Question
Old Apr 30, 2009 | 05:54 PM
Oldguard 7's Avatar
Oldguard 7
Default Window Question
There is a gap between the weatherstrip and the window on the passenger side window on the vette. It is not flush with the weatherstrip near the windshield. Do I need to remove the door panel and try to adjust the window aft? If I am unable to do so, should I purchase new components?
Old Apr 30, 2009 | 08:51 PM
hgm's Avatar
hgm
If the window works ok I would remove the door panel and adjust the window. Do a search, there are a couple threads that will explain all the adjustments.
Old May 1, 2009 | 09:30 AM
jdp6000's Avatar
jdp6000
Confirm thats the problem first. Measure the distance on the back side and compare with the driver side. Could it be the weather stripping?
If the window needs to move forward take off the door panel and adjust the tracks forward a bit. The bolts that hold the tracks are right at the top of the door frame. Keep in mind that they adjust front/back and in/out. So if you are happy with in/our mark the spot so you only adjust the front/back.
The easiest way to do it is to remove the panel. Site in the car. Tools in hand. Power the window up. Then loosen the bolts. Move it into position then tighten the bolts. You'll probably need an observer out side as well.
Jim
To Window Question
