I have a 75 Vert that's a boulevard cruiser/show car. I don't run it down the 1/4 mile track, race it anytime (except the occasional red light to red light with a Mustang) or rev it past 4,000 rpm every so often for very short periods of time.
So my question is: Does having after market headers beneficial? I was thinking of installing a set of Dynomax Headers, but I've heard "horror" stories about the fit, looks & heat with just about every system out there. Right now my stock rams horns look really good (just painted them last fall) So...if the headers don't provide any "seat of the pants" performance, then why mess with a good thing. Right now I've got the stock rams horns going to a dual exhaust system...2 1/2" to a set of FlowMaster 40 Series.
Should I go with the headers or leave "well enough" alone?
If you are all show and like what you have, keep it that way. I too have a 75 but mine has a 383 in it with the Hooker side exhaust. As far as seat of the pants difference, there is none. Remember I believe you have 180 HP, so stick with what you have.
By the way, looks great under that hood.
Right now I am having a hard time getting the ramhorn manifolds to fit on my vortec heads. There is clearance issues with the valve covers. I am going the grind the notches on the back of the mainfolds maybe 1/16 of an inch to make them fit. I used POR-15 manifold gray, it looks great.
VetteGuy - BigEarl, Great thread! I have been looking at the same headers for my 68 and have all the same questions. Looking forward to the update BigEarl. (hope you feel it in yer pants) Torque that is...
I had rams horns and full 2.5 inch duals on my car for a while. When I switched to Dynomax headers and Magnaflow mufflers I dropped about 1/2 second in 1/4 mile ET. Thats on a mild 383 engine. I think you will feel the difference.
If you keep your engine compartment that clean all of the time, you will have a problem with headers because after a couple years they could start to corrode, even the ceramic coated headers will start spotting. I have a modded 350 with Dynomax and really don't have any noticeable interior heat issues with mine.
With the top down and the sun baking you, it's hard to tell, right?
Good looking underhood you have there.
There are pro's and con's on this subject for sure. Headers on just about any engine will performer better if you tune the engine for it, some are ok right out of the box but usually that is because the engine was rich to begin with. Is it worth putting them on your engine? Only you can really say that, but they will be loader in side your car, you will have reduced under car clearance, and they will not last as long as cast iron, they will give off more heat. You said you have 2.5 exhaust now, does that mean you have 2.5 manifolds also? If you have the stock manifolds you could make things better and look stock with an upgrade to the early 2.5 manifolds. Is that worth the cost? only if you want stock looks and stock quite under the hood with better performance, but can you feel the difference? I would say yes if you tune for the improved flow. I could feel almost no difference in my 68 switching back to 2.5 manifolds from tubing headers, was well worth it to me.
Long tube headers will always out perform the rams horn manifolds - it's simple physics. If you run the headers into a factory type full exhaust system with all of the compression bent pipes the gain will be minimal vs the rams horns - maybe 2/10s in the quarter mile on a car like yours, but it will still be a gain. For a noticeable difference, run the headers into a mandrel bent system of a least 2.25" diameter and you will see gains similar to BKbroiler. Based on your info, I suggest leaving yours alone. Also, there is no mystical secret to headers - 10s of thousands of cars run them everyday. You can get headers that fit great and last forever for $85.00. People who tell the horror stories do not know what they're doing or talking about.
Picked up the car today but unfortunately it was raining so I couldn't get on it, which means I can't give an answer on increased power. I know it sounds better, but I couldn't take t-tops off, so I can't tell how much better. The guys at the shop said they had zero issues getting them in. (The kid working there said him and his "vette-head" dad just did a full resto on a '72, which made feel a lot better about leaving my car at Midas.) I've got plenty of room for spark plug wires and plenty of clearance from the ground. Hopefully tomorrow will be a clear day and I will be able to see if there are any real perfomance gains. I can post some pics if you want to see the clearances. Be warned that my engine bay doesn't look as nice as vetteguy's.
Weather was nice today so i got to take it out. The sound is awesome, my temperature was about 10 degress cooler too. Keep in my mind my old set up was the exaust manifolds with the air tubes uncapped. I can tell there is some more power too. Not much, but I can tell a difference. I am very happy with my decision. Here's some pics.
Driver side
Passenger side. One spark plug boot is close as you can see(on the right). The angle is a bit misleading. It's a half inch from tube, and thats the closest one. After cruising I came back and stuck my finger on boot. I dont think there will be a problem.
I am very interested in this subject. I plan on lowering my front 2" and want all my HP w/o dents in headers. I was thinking about the McJacks 1 5/8 welded headers. It will hopefully be the least compromise.
I mailed McJack about dyno results. He has a 100K stk 71 w/rh did 195 rwhp, w/McJacks 211 rwhp. That sounds about right to me. In my reading, the stronger the engine, the greater benifit from headers.
I read an article where a hi rpm sb gained over 40 fwhp w/headers over rh, anyone else read this?
My 74 has 280 rwhp w/stk rh ex. Anything over 300 rwhp would be nice.
Am I being too optimistic?
Ricisan
I only know a fraction of what most of the guys on this site know, but it is my understanding that long tube header benefits are at high RPMs/WOT. I was going to go with some shorty's but I heard to many horror stories about burning motor mounts, spark plug wires,etc.
Ricisan
Sanderson shorties, cost a LOT less than McJacks, and fit fine. My car is lowered as well, at least 2 inches in the front. I'll have some picks to show sometime later on this week of my set up.
