Port Match Intake to Head Worthwhile?
TT
First, I'd hope the intake requires more work than would the heads. Then, if these heads are indeed '67 L88/L89, aluminum, closed chamber, rectangle port BB's, dated from back in the day, are you really sure you want to touch them? If you're OK with that, I'd tend to err on the side of caution should you choose to do very much to them, concentrating pretty much on any gross irregularities from small port to small port, and from large port to large port. It is NOT necessary to hog things out to the gaskets. Besides, achieving a proper match is all about the transitions from the intake runners into the ports, so don't get caught up in how big are the port cross-sections of modern heads.
FWIW, the more aggressive you get with enlarging any port cross-sections at the gasket, the more blending them well into the head ought to be done so as to not introduce a sharp variance to the rate of taper flow will encounter just after the runners enter the ports.
Yes, one could do even more, but IMCO any further into it than this, and we're talking more about head porting than we are runner/port matching. Hope that's worth more than you paid for it.
TSW
TT
TT
As long as you manifold ports are smaller than the head leave them alone. You can match ports all day long because one thinks it looks better, but unless you flow the together what ever you do is just a guess!
TT
With Skunkworks. Don't port the heads. Don"t gasket match anything. What I did was take a piece of thin cardboard and put it on the head flange. Then I took a sharp exacto knife and cut the bolt holes out. Inserted short bolts and used the exacto knife to cut the cardboard out to match the head ports exactly. Then I bolted the cardboard to the intake and darkened the area that needed to be port matched on the intake with a marker. Then removed the cardboard template. Using a dremel I removed material till the darkened area was gone. Then I worked my way into the port of the intake making sure I transitioned it well into the intake with no visable restrictions. This matches the intake port to the head port exactly without ruining the heads for a later sale or in my case changing the flow characteristics of my competition ported AFR heads. As long as the gasket opening is very slightly larger so it don't protrude into the port opening anywhere your good to go.
TT
It seems to make sense that a small intake port leading into a larger head port would work because there is no physical restriction to flow. But in reality, cylinder filling efficiency is also based on velocity. The flow path must gradually be REDUCED throughout the run. This increases velocity so the A/F mixture is accelerating into the cylinder. If, as the mixture enters the head, the size of the path opens up, the airstream stalls and flow is reduced.
If you are worried about the value of your heads, leave them alone. But if you are going for performance, you absolutely must portmatch (also unshroud valves, blend bows, polish chamber and exhaust port, smooth short side radius). Otherwise, you are just leaving HP lying on the bench.
In the C4 Corvettes, GM was able to add 30 HP to one model (I forget which one) by porting and polishing.
God bless, Sensei
Here are 2 things I wont do on a street car
1. Smooth intake and head runners
2. Use racing fuel (racing fuel burns colder and slower). The hotter and faster the burn, the more power it will produce. I also know a guy who holds the world record in stock class boat racing and he says the lower the octane you can run, the more power it will produce because it burns faster & hotter. There are also articles floating around on this..
I was just about to say pretty much the same thing. Interestingly, Reher-Morrison has found that a miniature corrugated pipe type texture in the intake runners actually improves flow at high intake runner/port velocities. (High intake runner/port velocity is your friend.)
And, having the A/F charge run into a substantial impingement on its way to the valve from the carb introduces all kinds of disturbances which harm runner/port flow efficiency. If such is "needed" to improve fuel atomization you've got problems which would be better addressed by other means.
As for a step from smaller runner to larger port, many years back, Edelbrock experimented with raising the floor of the runners approaching the larger ports (some ~3/8" or so) in an attempt to level out flow between the two types on the old TR-2X tunnel ram (if I still had one I'd post a pic). In practice, this didn't actually improve anything as it only made the better ports less efficient. If it had been the thing to do, you'd best believe this practice would have become wide spread. It's not.
Finally, it's worth noting that efficient ports don't do anything to hurt fuel economy; that's more a function of other variables, the weight of ones right foot being prominent among them.
All nitrous does is further atomize AF (hence the reason they refer to it as a fogger) so there is room for more and the more atomized AF you stuff in a combustion chamber, the bigger the boom.. Modern tech has also yielded further designs such as injectors (mist sprayers), valves and combustion chambers to help further atomize AF ratios for more power and improved gas Mileage.. Back in the early 70's even Bill Jenkins knew that if he further atomized fuel he could make more power so he began experimenting with screens under the carb..
TT
