fuel pump wont pump
Old May 2, 2009 | 04:56 PM
lilypad's Avatar
lilypad
Default fuel pump wont pump
Brand new fuel pump on the car,ran fine for a few minutes earlier in the week,but today no fuel.so I took off line pre pump and plenty of gas running with gravity but no gas on outlet side of pump. The motor is fresh with less than an hour on it.Am i missing something or do I have a bad brand new pump?? Thanks for any advice.
Old May 2, 2009 | 06:43 PM
Bullet81's Avatar
Bullet81
When you replaced the pump did the pump rod fall out of the engine? I'm sure you have checked this already but this is the only thing I can think of if you have gas going to the pump but not up to the carb.
Old May 2, 2009 | 10:14 PM
my 76 ray's Avatar
my 76 ray
I once had a problem with a pump because the rubber hose connected to it must not have been making a good seal. Mine was on a Blazer and it had a flexible hose so I just cut off an inch to get to a fresh piece of hose and it worked fine.
lilypad's Avatar
lilypad
Well the rod did slide down and i pushed it back up and put the pump back in it went together good. I guess I could take it back out and check everything againg but i Ithink its a faulty pump.
Old May 2, 2009 | 10:24 PM
temvette72's Avatar
temvette72
Remember that NEW stands for Never Ever Worked. Could be a defective pump!
Temvette72
Old May 2, 2009 | 10:25 PM
Grumpy 427's Avatar
Grumpy 427
I had a Holley mechanical 110 GPH that was a dud out of the box. What brand of pump do you have
Old May 2, 2009 | 10:55 PM
lilypad's Avatar
lilypad
just went to napa and got one
Old May 3, 2009 | 06:33 PM
Grumpy 427's Avatar
Grumpy 427
yeah make sure you have the push rod up all the way, get another pump and try it again. It sometimes takes a few cranks to get the fuel into the carb and get the float bowl full.
Old May 3, 2009 | 07:09 PM
Lotadoh's Avatar
Lotadoh
It may sound stupid but I have had to pull the carb line off and suck gas through a pump, to prime it. Worked great ever since.
Old May 3, 2009 | 09:41 PM
Grumpy 427's Avatar
Grumpy 427
Sounds like some vapor lock going on.
To fuel pump wont pump
