Got 1 in
Old May 2, 2009 | 06:54 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Got 1 in
Should have the other in tommorow.
Then to figure out how to mount to the covers.
Old May 2, 2009 | 07:07 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
What's your plan/direction with the car?
How are those covers subsequently blended into the body and how do you later change bulb?
Old May 2, 2009 | 07:10 PM
Guru_4_hire
Cruise-In V Veteran
They are sort of thumb screwed down, and then you just unscrew the covers and replace the bulbs.
www.fgreggracing.com has some pictures.
Its a tinker toy.
Old May 3, 2009 | 12:27 AM
TimAT's Avatar
TimAT
Looks good! How about mounting the covers with Dzus fasteners? 1/4 turn and they pop off. There are flat heads, button heads, or even wing style. All are a quick release. Or a piano hinge at the front and then the Dzus at the rear.
Just my thoughts. I'd guess you already figured out a plan.
Old May 3, 2009 | 07:25 AM
Guru_4_hire
Cruise-In V Veteran
not really. Its been a royal pain just getting the buckets in.
All I know is that I need 6 ish fasteners 3 from 3 back.
Old May 3, 2009 | 07:37 AM
TimAT's Avatar
TimAT
Here's another thought- put a piece of aluminum angle across the front, mounted so the covers slip under it and then the 3 quick release across the back- That will keep air from lifting the front of the cover too. There's a picture of a setup like that on another forum somewhere, but I don't remember where.
Old May 3, 2009 | 07:43 AM
Guru_4_hire
Cruise-In V Veteran
I thought about that and got some angle aluminum got cut it to length and got a universal drive wrench and started beating into the right angle. Changing the angle of angle aluminum makes it curve apparently.
I am digging the hinge idea that i can drill my own holes in. So I can line them up with the holes for the bumper.
To Got 1 in
