Water Temp sender mount location
Old May 2, 2009 | 08:05 PM
TXredc3's Avatar
TXredc3
Default Water Temp sender mount location
Is it possible to mount the temp sender in the intake manifold and it register correctly? Anyone done this?
Old May 2, 2009 | 08:07 PM
midyearvette's Avatar
midyearvette
yes...intake close to the thermostat housing......
Old May 2, 2009 | 09:27 PM
TXredc3's Avatar
TXredc3
What about the opening on the opposite side of the manifold....closer to the side of the manifold that is closest to the windshield?
Old May 2, 2009 | 09:58 PM
midyearvette
if you are talking the rear of the manifold, there is no coolant passage there if i am reading your post correctly.....the passage is in the front, so anywhere there is ok...or cylinder head...........if you are talking about tapping the rear passage in the head that is blocked by the manifold, i dont think you have enough meat on most manifolds??
Old May 2, 2009 | 10:01 PM
carriljc's Avatar
carriljc
Default mine is mounted on the intake and reads low....
I'd say about 40°F low.
Old May 2, 2009 | 10:24 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
possible yes, Ideal .....NO. you want to know your Head Temp.
Old May 2, 2009 | 10:31 PM
midyearvette
intrestingly enough, mine is mounted in the cyl. head and i have an engine thermometer mounted in the intake where the temp sender usually goes on a big block and both gauges read the same!.....
Old May 2, 2009 | 11:03 PM
TXredc3's Avatar
TXredc3
What exactly is an engine thermometer? Does it measure water temp? Where on the manifold is it located?
Old May 2, 2009 | 11:10 PM
midyearvette
it is permanently mounted in the intake next to the thermostat housing and takes all the guess work out of correct engine temperature...the dial is calibrated from 50-300 degrees........
Old May 2, 2009 | 11:35 PM
CCrane65's Avatar
CCrane65
Now, in my big block the hole next to the thermostat housing is the heater hose port. My temperature sender is in the left head same as the small block.
cc
Old May 3, 2009 | 12:07 AM
OMF's Avatar
OMF
The temp probe located at the thermostat is the best location, because it is the temp of the coolant (the warmest it will get) just before it goes to the rad.
Old May 3, 2009 | 08:50 AM
midyearvette
cc
sorry my mistake...i run an edel. performer rpm...:o
Old May 3, 2009 | 10:41 AM
baxsom's Avatar
baxsom
i am using the transdapt thermostat housing that has the threaded hole in it to mount my electric fan temp probe.
when i compared it to the temp sender to the dash in the intake right to the left of it. there was only a 10 degree difference in temp.
To Water Temp sender mount location
