Help with steering effort
Old May 4, 2009 | 01:02 PM
cherrybombc3's Avatar
cherrybombc3
Default Help with steering effort
Ok, finally replaced some steering components to clean up the leaky mess under the car.
I have test driven the Vette after installing a steering gear box &
control valve. Both items were rebuilt from a very reliable Vendor (Supporting Member)The centering was adjusted great on the valve and everything was aligned text book perfect (gear box centered @ high spot, flats @ 12 o'clock on the input shaft & column shaft, steer wheel & hub aligned with hash marks @ 12 o'clock, great! Tie rods adjusted to equal lengths & to set. Took it to the alignment shop & had her aligned, also great!!
But it was apparent on the way to the shop that my steering is sticky or firm & does not return to center on it's own after making a turn. It's equally sticky or tight in each direction, just consistently tight & won't re-center in either direction. I can’t make a turn with my finger in the spokes of the steering wheel as I used to do. It now requires two hands (almost)
Since I did the gear & valve separately, I can say the valve made no difference, hence I believe the problem is in the gear box.
Any suggestions to loosening the steering up??
Old May 4, 2009 | 06:24 PM
Duke94's Avatar
Duke94
Have you had a wheel alignment yet after replaceing the steering parts? Caster will effect steering wheel return.
Gary
Old May 4, 2009 | 06:45 PM
GTR1999's Avatar
GTR1999
sounds like a box, what spec was it set to? preload, lash, were new gears used?
Old May 4, 2009 | 08:12 PM
08vycpe's Avatar
08vycpe
It does seem like the steering box as GTR mentioned. I had the same issue the first time I adjusted the steering box last month. It did not return to center after a turn very well and was kind of sticky. After the second adjustment I got it right. Make sure you do the adjustments with the gear at top center and in the correct order.
Old May 5, 2009 | 07:09 AM
cherrybombc3
I did have the alignment done by my usual tech, very good! I believe it is the box's worm gear lash adjustment. It is a rebuilt box, yes with new gears by a reliable source. I am not aware of the preload specs. I will try backing off the worm gear lash adjuster a bit at a time and see what results I get. Thanks for the help Guys.
Old May 5, 2009 | 07:14 AM
cherrybombc3
Thanks, I am framilair with the top center orientation of the box as you mentioned but what did you mean by the correct "order"?
Old May 5, 2009 | 03:33 PM
08vycpe's Avatar
08vycpe
You HAVE to do the worm gear lash first (the big nut and lock ring from the steering column) then the output shaft lash). See "poor man's method" section in this Lars paper.
http://www.corvetteactioncenter.com/...ear+Adjustment
I put in new GM steering gear lube and then adjusted the gear. See pic attached for the correct GM part number. Don't use chassis grease. Remove the lower bolt only in the 3 bolt pattern for the cover as you look straight down on the gar. Fill to this hole and don't overfill. Allow for airation and expansion. I used a large siringe because it was neat but you can use a grease gun.
Old May 5, 2009 | 10:32 PM
cherrybombc3
Gotcha, thanks for clarifying. Looks like I have another small project this weekend! HA! This should be the last detail on the front suspension so I am quite excited to get it right & go for a ride.
To Help with steering effort
