Reflect-A-cool
I am assuming it will be exposed by the question about lines in the roll......I would NOT put that under your hood for any reason, it is good for under carpet or on the INSIDE of the cockpit.....but my advise, if I am reading this right is to not reflect heat back at the motor. It should be covered by "something".
Has anyone seen hood paint ruined from engine heat when the under hood pad was not installed?
My under hood factory pad was so dirty, that I removed it about 5 years ago. No problems.
Just after I bought my vette, I had it at a local car show.
Beautiful cloudless sunny day, with the bonnet up.
I was sitting with a group of club mates when I was informed there was smoke coming from my engine bay
Sure enough.
The hood insulation was smouldering.
As it happened, the top of my chrome air filter had a concave centre section which magnified the reflected sunrays into a nice hot spot (just like a magnifying glass) and had burnt a 2" section of the hood lining.
Lesson learnt.
As said before.... underhood lining was for noise, not paint protection.
After installing my L88 scoop, I had the underside painted with a coarse hammertone black paint, similar to what is sprayed under guards, which looks quite effective.
Sure enough.
Lesson learnt.
