Doing a top build on '77 L-48 (Cam, lifters, Z-28 heads etc) and not sure which way to go on exhaust system. Not too happy with original exhaust manifold and am leaning toward a set of headers. Not looking to break the bank, but just want a good set on bolt ons & go..
I will personally never buy un-ceramic coated headers again.. With that being said, if your just looking for cheap un-coated headers, Summit has some for $90 and that includes gaskets, collectors and bolts, which is hard to beat.. Summit #G9003
Summit headers are a good deal, but don't get them if you ever plan on lowering your car from stock height, IE, aftermarket suspension stuff.
I went with summit, but had MAJOR ground clearance issues, due to my car being lowered 2 inches from stock hieght.
Now I have sanderson shorty headers, they fit easy, sound great, and, to be honest, will yield the same results as full length headers, unless you are running a fairly high compression motor...and you wouldn't really want to do that on an L-48 anyway.
Sanderson makes outstanding quality headers...the thickest flanges you'll find so the bolts won't back out, thicker gauge steel. Just an excellent product. As already said...get ceramic coated.
This is just not true. Full length headers will produce more torque and horse power than the shorties - especially on your motor with your mods. The Summit and Jegs headers are a super value. I have used several sets and have never had a problem with fitment, performance or durability. Why spend a few hundred dollars for something you can have for less than a hundred?
If all you care about is not leaking, Sanderson makes good headers.
If you are actually trying to improve performance, there are much better choices.
Sanderson's collectors are horrible. They are not a smooth transition at all.
They merge the tubes very abruptly which is going to cost you power.
Corvette SB manifolds are good for manifolds & shortys are mainfold replacements. May or may not make more power. Next up are compromise headers like 3/4 length & Tri-Y.
At the top for Corvette SB are full length Dynomax Cerma Coat & Hooker Super Comps.
Thanks for info. I read up on the Summit #G9003 and they require 3 different mounting brackets for alternator, A/C, etc. So, apparently there are some clearance issues or they are trying to sell me something I don't need. I want to use my original brackets if possible. Did I read the data sheet correctly??
Assuming you have the short R4 compressor there isn't a problem for 77. Only a spacer for the A/C bracket to manifold is needed w/ headers & even that is not necessary. .
Terry
If your interested, I have a nice pair of SB Hedman headers. They are black and were installed new and probably dont even have an hour of run time on them before I threw a pushrod and then decided to pull the motor and replace with a fresh 355 and ceramic coated Hedmans.. $120 firm plus shipping.. They have some scratches but there are no dings and they still look fairly new..
If you want to keep the A.I.R./smog pump connections, Heddman sells a set with the pipes welded into each tube. I think it is #68301. I ordered mine from Jet-Hot, coated, but now, after living in Ohio since 2005, my lower tubes are showing signs of rust in the Jet-Hot coating (could be rusting from the inside-out). I paid over $400 delivered back in 2000.
Be wary of parking lot speed humps... I dented one of my tubes on the passenger side header; not severely.
I put the Summit brand on my A/C equipped '79 and it was a breeze. No extra brackets needed. I did have to fabricate a spacer for the A/C mount - but that was very simple - just had to cut a piece of 3/8" pipe about 1.5" long. Nothing needed for the alternator.
I have loads of ground clearance with my stock suspension.
Any advice???? Thanks,
Terry
Not to change the subject, but I did the same thing on my 76, L48, top rebuild 3 years ago with new cam, rockers, intake, valves, springs, etc. Now I am rebuilding the whole engine and have to redo the top end again. Guess I put too much into the top end and blew some rings and wiped some lobes on the new cam. This time I'm going with roller cam and roller rockers. Save yourself some heartache and money latter on and just rebuild the whole engine now. Just my 2Cents.....
