Where to go from here?
I have a cheap block (made in mexico good wrench 10066036) with low end heads (33417369), Edelbrock 600 carb, edelbrock rpm intake, chambered headers, and an electric fan. Its on a 4 speed car.
If I were to guess, the car is probably pushing 260hp/300lbs at the motor.
My real question is what to do next? Is it really worth putting a cam or head swap in this all cast low end motor? Is the block worth even taking out and building up with forged components? I read this series which starts with the same cheap heads and block, but would any of those mods really be worth it? Im considering buying a better crate motor or just building a decent motor in the garage.. Not exactly in a hurry to do anything on it, the car runs great as it sits.. just needs some more oomph.
With the existing motor you can do a cam swap fairly cheap. You can get the heads ported and angle milled. Still you will only get so much flow from them. You can gasket match the intake. You can get lightweight pistons and zero deck the block. You could get a 383 kit and redo the whole bottom end, but you will have to consider the heads for this as well. At that point I am building a new motor ground up.
http://www.compcams.com/Cam_Specs/Ca...x?csid=87&sb=2
Honestly its running great as it sits.. timing is dialed in perfect and very smooth so leaving it alone and building something over the next couple of months wouldn't hurt my feelings one bit.. But with a hecho en mexico block with a cast crank, cast rods, and cast pistons you run into a point where spending cash on it vs buying something like a nice dart block and building it in the garage is reason to debate.
Thanks for the input guys!
