Fuel Line Fitting
Old May 7, 2009 | 07:00 PM
willem wallace's Avatar
willem wallace
Default Fuel Line Fitting
Making up a 3/8 solid fuel line set-up on my stroker. Have it pretty much under control with use of standard brass fittings, however the carb fitting on my Edelbrock is proving to be a problem to find. It is a single line feed, and I believe the fitting I need is a 5/8"-20 male into carb housing, then want to attach to 3/8" steel line. Don't want to pay ridiculous fitting price plus shipping! Any suggestions?
Old May 8, 2009 | 06:04 PM
willem wallace
ttt
Old May 8, 2009 | 06:11 PM
thebruce's Avatar
thebruce
Same things happened to me. I had trouble finding the fittings recommended by Lars in his "How to Build a Fuel Line" paper. I looked all over for the replacement fuel line he recommended, and I couldn't find anywhere that still stocked that part number. As it turned out, NAPA had it (and a ton more) included in their different fuel line repair kits. You might get lucky and find the one you're looking for. If I remember correctly, they had about ten different kits with different fittings already flared onto 12" of 3/8" stainless.
To Fuel Line Fitting
