Tips on u-joint installation
Old May 8, 2009 | 08:00 AM
AWilson's Avatar
AWilson
Default Tips on u-joint installation
Any one have tips or basic instructions on u-joint installation? Old ones are already out.
Old May 8, 2009 | 09:08 AM
Rally68's Avatar
Rally68
There is excellent info on this topic, here on the forum. Do a search for "u-joint install"
I read these threads before I did mine:
http://forums.corvetteforum.com/c3-t...many-pics.html
http://forums.corvetteforum.com/c3-t...t-install.html
Good luck!
Old May 8, 2009 | 02:25 PM
redman76's Avatar
redman76
St. Jude Donor '09
Rally is right, do yourself a favor and search through the CF threads; lots of great info. Getting them off is much harder than getting them back on IMO. One thing to watch for that bit me is when you are putting the caps back on, be very careful not to dislodge any of the needle bearings. I was finishing my last one and while tapping the caps on, 3-4 needles came loose; I couldn't figure out why the caps would not go on all the way. I pulled it a part and found I had broke 3-4 bearings. Just go slow and check and double check. Man, I hate replacing brand new parts -- it wasn't the first time and it won't be the last time, but it always hurts.
Old May 8, 2009 | 02:44 PM
AWilson's Avatar
AWilson
Thanks guys.
Old May 8, 2009 | 02:55 PM
pauldana's Avatar
pauldana
Originally Posted by AWilson
Thanks guys.
Don't use a hammer or air hammer to get them out, you will bend the flanges and put the axial out of balance. I would have them pressed in and out at a shop that can also balance the shafts afterwards. While you already them out... not that much$$$ Vibration is a B@$#
Old May 8, 2009 | 02:59 PM
Peterbuilt's Avatar
Peterbuilt
If you don't have this tool http://www.volvette.com/page/vvp/prod/tools/tl30 then bolt the flanges together so they don't bend. PG.
Old May 8, 2009 | 03:30 PM
Vette79C3's Avatar
Vette79C3
To avoid bending the flanges, I had mine done at the shop and balanced. Installed Spicer U-Joints without the Zerk Fittings.
Old May 8, 2009 | 08:45 PM
Paul71LT1's Avatar
Paul71LT1
I cleaned up the bores with a sanding drum on my dremmel tool to remove all corrosion and get shiny metal on 100% of the bore, then warmed them up a bit with a torch. I used the jaws of my 6" bench vise as a press and smoothly pressed them together. No hammers. It dislodges the needles.
Old May 8, 2009 | 09:26 PM
Duke94's Avatar
Duke94
Here's another how-to article.
Gary
http://www.corvettemagazine.com/tech...rticles/c2/41/
Old May 9, 2009 | 01:06 AM
pauldana's Avatar
pauldana
I would still have them balanced now while you have them out.
Old May 9, 2009 | 09:51 AM
sting66cp's Avatar
sting66cp
A shop recently quoted me about $40 for each for spicer u-joints for my half shafts, not including installation. Does this price seem fair?
Old May 9, 2009 | 08:37 PM
Rally68's Avatar
Rally68
Duntov sells them for $46 per pair, free shipping
Old May 10, 2009 | 03:39 AM
AWilson's Avatar
AWilson
Got it done today. No problem really.
Thanks guys!
To Tips on u-joint installation
