'72 Wiper door will not open!
Old May 9, 2009 | 12:40 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Default '72 Wiper door will not open!
Worked fine last week, went to use it tonight, and the wiper door wouldn't open! It wouldn't open with the manual over ride switch either! I disconnected the vaccum hoses from the wiper door actuator, and then manually opened the door and then the wipers operated fine.
Where do I start to look? How do I troubleshoot this?
TIA
Old May 9, 2009 | 07:51 AM
baxsom's Avatar
baxsom
make sure you have vacuum to the lines.
mine did the same thing and it turned out to be that pointed rubber seal (sometimes called the witches hat) inside the acutator was torn.
Old May 9, 2009 | 09:26 AM
...Roger...'s Avatar
...Roger...
With the engine running and all hoses hooked up remove the small hose from the wiper door relay. This should make the door pop up,let us know what happens.
Old May 9, 2009 | 02:40 PM
7t2vette's Avatar
7t2vette
Okay, I fixed the problem. I checked the vacuum system while the engine was running; specifically I checked for vacuum on both hoses from the wiper door actuator and found them to both be operational. Then I focused on the actuator itself, and quickly found the actuator rod seal (AKA "the witche's hat") had somehow popped out of place. Pressed it back in, and it works fine now.
Old May 9, 2009 | 09:33 PM
baxsom's Avatar
baxsom
hey i actually got one right
sweet
To '72 Wiper door will not open!
