Battery gauge question
New circuit board(green plastic)
All gauges/lights working properly.
Ammeter/battery gauge not moving at all
Dismantalled the gauge and with my electrical expert friend, we can't seem to get her to work.
He applies direct power and the gauges goes right to the top (18)
He checks the resistor and it reads in the 124's....
When we reinstall into bezel and plug it in, nothing
Is there any documentation available for the specific gauges ?
My friend can read the diagrams pretty good.
Any tips from any of you electrical gurus ????
My friend is questioning the resistor. Is 124 too high ?
He's thinking of building his own resistor for my gauge to work properly.
Input anyone ????
Phil
About the best way to test the gauge is to check for polarity between the poles. If you want to do a low volt quick check you can use two double A batteries and solder them in a series. Then solder a power wire from one side and a ground to the other side.
When done, you can touch this over the poles and the gauge should move one way, reverse this and the gauge should move the other. Aside from this there really is nothing else you can do to the gauge. If the gauge pass’s this test it is working and I would look for a wiring issue with the car.
Willcox
18243
Willcox[/QUOTE]
Thank you Sir !
My friend will read these answers once he's back from his cottage.
The circuit board is new. All lights and gauges are working properly except the ammeter.
HE did several test(s) with the gauge and another spare one. He is satisfied that both are working properly.
When the gauges are screwed back to the bezel and the harness is plugged in, all works except the ammeter.
Is it possible that the resister is defectuous ?
When testing the resister on the voltmeter, what reading should we get ?
What is a proper way to test the resister ?
What other wiring should we be looking for ? Alternator ?
My friend will be checking on your answers. Go ahead and don't be afraid to reply technical. I'm sure HE will understand !
I'm sure I won't
Thanks again Sir !
Phil
