Installing new starter
Old May 9, 2009 | 05:07 PM
wood_worker_1's Avatar
wood_worker_1
Default Installing new starter
74 350/auto - New starter solenoid does not have R/I terminal (old starter did) QUESTION: Where do I hook wire that ran to R/I terminal on old starter? Was told just to tape it up but car will not start. Thanks
Old May 9, 2009 | 05:49 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
what Distributor do you have ? points or HEI ?
what wires do you currently have connected ?
If points you will need to add a Diode, or Relay.
69VETT
Old May 9, 2009 | 06:10 PM
wood_worker_1
69VETT
Points - Battery wire and alternator wire to "B" terminal Start/Iginition wire to "S" terminal No R/I terminal to hook coil wire to. Double check with parts house supposely correct starter. Thanks
Old May 9, 2009 | 06:22 PM
Peterbuilt's Avatar
Peterbuilt
They gave you the wrong starter, try another parts house. PG.
Old May 9, 2009 | 06:24 PM
69Vett's Avatar
69Vett
if possible take the starter back, and get one with a run terminal.
I assumed he volunteered to go mini-starter.
with no Run terminal you will have to add a Diode or Relay.
Old May 9, 2009 | 07:37 PM
Ironcross's Avatar
Ironcross
The switch that is on the new starter is for HEI ignitions and it is also shorter than the old switch. Possibly they gave you a metric starter as they are almost identical in appearance and only experienced counter people would know that problem....
Old May 11, 2009 | 05:48 PM
wood_worker_1
Problem solved! Parts house sold me wrong starter/in the right box.
To Installing new starter
