My new Speed Demon came with .031 discharge nozzles. The holley I was running before had .045 squirters. Will the old holley squirters work, or should I stay with the nice smooth BG style squirters. Also, could I just drill out the .031 squiters that came with the Demon?
Also, will the holley style acc pump cams work or will I have to buy cams specifically made by BG.
Re: Question about Demon discharge nozzles (jeffs)
I drilled mine out to .044 or .045 I don't remember which. The holley cams work fine. I set my pump for next to Zero gap so it squirts as fast as it can. I'm using the 7532 Weiand with 1/2 inch wood heat spacer.
i use 4.11 rear. I figured out that the 3.90's would be the best gearing with a 700
