Brake bleed simple questions?
Old May 11, 2009 | 01:03 PM
bgall2's Avatar
bgall2
Default Brake bleed simple questions?
These may be stupid questions but here goes:
1. Does the engine of my 78 need to be running during brake bleed process?
2. Dot 3 or Dot 5?
3. Can I mix Dot 3 & Dot 5?
Old May 11, 2009 | 01:10 PM
Scott Marzahl's Avatar
Scott Marzahl
Not running and NO do not try mixing them. If you are running DOT 3 just use a high quality fluid, something like Castrol which is rated DOT 4 rather than DOT3 for normal street use.
Old May 11, 2009 | 02:01 PM
VettePower's Avatar
VettePower
You can use DOT 4, but not 5. And car does not have to be running. If you do the gravity bleed method, it will take a little longer, but works great.
Old May 11, 2009 | 03:42 PM
joewill's Avatar
joewill
gravity method works wonderful, especially when you are working on your car by yourself.... which is almost always for many of us...
Old May 11, 2009 | 08:19 PM
Sebago Shark's Avatar
Sebago Shark
St. Jude Donor '09
Read the "Sticky" at the top of this tech section. I never did this kind of stuff before and it helped me out a lot. My wife helped me and it worked great. Had a mechanic check it and he approved.
To Brake bleed simple questions?
