HELP!!!!.... Jump starting vette?
Old Feb 4, 2002 | 10:02 PM
ddn's Avatar
ddn
Default Re: HELP!!!!.... Jump starting vette? (Ganey)
Do NOT mess with the cables when you are cranking the car over. You'll get a spark that'll melt your brains from the huge draw. Clean both sides, likely you aren't getting a good connection.
Just plain WATER works great for cleaning corrosion from battery terminals.
Old Feb 4, 2002 | 10:03 PM
PatsLs1vette's Avatar
PatsLs1vette
check the ground under the car to the frame...could be corroded and not getting a good connection.
Old Feb 4, 2002 | 10:08 PM
BADCAIMAN's Avatar
BADCAIMAN
Default Re: HELP!!!!.... Jump starting vette? (Jenny)
If you can avoid it...Don't ground to the battery..I use to do it all the time..Untill I was jump starting my buddies car and I reached over to make sure he had a good ground on the battery..And the thing let go...Sounded like a shot gun ...We both got covered in battery acid...We then had to wash the cars....We were lucky no one got hurt...Good luck
Old Feb 5, 2002 | 09:26 AM
Tom454's Avatar
Tom454
Default Re: HELP!!!!.... Jump starting vette? (BADCAIMAN)
For what it's worth... I tightened the side post cable ends already. They are clean & tight.
It's either a loose cable to ground, or a loose cable at the starter, or a bad/loose ignition switch.
I witnessed the first episode... in my driveway. Tightened the positive cable at the battery and it started right up. Thought the problem was solved... obviously not.
If you don't make any progress, let me know ASAP and I will come over to fix it. Better hurry... Sunday's approachin' ...
