L36 4 bolt mains?
Old May 11, 2009 | 07:54 PM
Jim Bart's Avatar
Jim Bart
Default L36 4 bolt mains?
I have a early 69 L36, does this engine have 4 bolt mains??
Ty Jim
Old May 11, 2009 | 08:25 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Ty Jim
Sorry Jim, the L36 came with only 2-bolt mains, according to Alan Colvin, both early and mid-year (270 and 512).
Old May 11, 2009 | 09:39 PM
baxsom's Avatar
baxsom
pull the pan and check.
the casting # on my 454 says it is supposed to be a 2 bolt but when i pulled the pan there were 4 bolts on each main cap
Old May 11, 2009 | 10:33 PM
71rdster's Avatar
71rdster
Casting number rarely dictates 2 bolt or 4 on big blocks. The engine stamp tells the tale. L36 is going to be a 2 bolt. Both my 66 and 68 L36 motors were 2 bolt. The good news is that it can be made into a 4 bolt block at any decent machine shop.
Old May 12, 2009 | 12:06 AM
1969vert's Avatar
1969vert
Well I have a different opinion. I checked the casting #'s, casting date, and the vin and they are all correct. My early 69 L36 has 4 bolt mains. I had the pan off...unless someone made it 4 bolt
Old May 12, 2009 | 02:31 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I know for sure that the 512 blocks could be eith 2 or 4 bolts blocks, the 4 bolts version for the L88s,L71s,L89s,LS6s .. etc, and the 2 bolts for L36,LS5 .. etc, now sometimes you could find some of the later engines that uses a 4 bolts block, maybe the guys at Tonawanda just use a 4 bolts blocks when they ran out of 2 bolts ones.
To L36 4 bolt mains?
