69 427 cooling-pressure
Old May 13, 2009 | 01:02 AM
elle88's Avatar
elle88
Default 69 427 cooling-pressure
is pretty hot here in these days...
half an hour "spirited " ride yesterday and engine temp was Ok ( 185F at cruise, 195F in the town at slow speed) but I found the coolant hose to be hard and pressurized and a little coolant flow out of the coolant reservoir tank.
I have new Alu heads , dewitts Aluminum rad , fan shroud , 180F thermostat, 50/50 aluminum type coolant and distilled water
should I increase the coolant % to raise the boiling point further to avoid pressurization?
Old May 13, 2009 | 01:08 AM
TimAT's Avatar
TimAT
There will not be much "flow" from the tank- once the radiator is full and the system is hot most of the coolant will circulate thru the radaitor and engine. Not all, but most. YOur radiator cap will take care of the pressure, so the hose being hard is not an issue. If you're running much over a 50/50 mix of coolant and water you're wasting $$.
That pressure you're feeling is actually raising the boiling point of your coolant.
Old May 13, 2009 | 07:51 AM
bashcraft's Avatar
bashcraft
You can't avoid pressurization. It's very necessary to avoid boil overs.
My '69 doesn't have a coolant overflow/recovery tank so I'm assuming yours doesn't either. If the system is completely full when cold, it will spew some coolant out when it heats up. The fluid level will stabilize after several heat cycles.
Old May 13, 2009 | 09:41 AM
Mike Ward's Avatar
Mike Ward
My '69 doesn't have a coolant overflow/recovery tank so I'm assuming yours doesn't either. .
BTW- No Corvette prior to 1973 had a coolant overflow/recovery tank.
Old May 13, 2009 | 12:47 PM
elle88's Avatar
elle88
my 69 427 has the expansion tank....an Harrison aluminum made.
one of my books says that the expansion tank was fitted on :
68: SB without AC and L88
69: SB without AC , BB with AC , L88, L71
Old May 13, 2009 | 02:14 PM
Mike Ward's Avatar
Mike Ward
That's correct, but no Corvette prior to 1973 had a coolant overflow/recovery tank.
Old May 13, 2009 | 02:37 PM
midyearvette's Avatar
midyearvette
i installed a small block surge tank on my 66 big block and adapted it for a recovery system by using a vented cap at the rad and a sealed cap at the surge tank..works quite well and will run 180-185 with no pressure on any hoses...after 190 especially in parades it will build pressure as the vented cap closes ...........this way there is absolutely no coolant loss as it is captured and returned to the rad as the mill cools or after a long shut down.......
To 69 427 cooling-pressure
