EdelBrock Performer 2116 / headlight vacuum issue
Old May 13, 2009 | 01:42 PM
reddog76's Avatar
reddog76
Default EdelBrock Performer 2116 / headlight vacuum issue
Anyone use the EDL-2116 and have issues with headlights not popping up properly? All main vacuum lines are hooked up on intake to main ports just like factory was except no EGR stuff, choke, etc... All remaining ports on stock Q-jet from factory air cleaner (replaced with drop-down) are plugged on carb. Checked and double-checked but this one is strange. Car sat for a few months during process of top end rebuild. I'm going to trace lines back but was curious if anyone had an issue with this setup.
Reddog76
Old May 13, 2009 | 06:00 PM
Ganey's Avatar
Ganey
Performer Vortec Dual Plane intake is not the issue.
The Q-J has plenty of ports to connect everything properly so it probably does not have the vac. lines connected right. Check PCV & evap. hoses- separate not to everything else.
Or
Little vac. is needed for the headlights, could be vac. leak like vac. tank.
Old May 13, 2009 | 09:15 PM
mikep3's Avatar
mikep3
I did a Vortec Head change with the Edelbrock 2116. Only have 15" with my cam 210/216 .420/.454.
What cam do you have and is your timing correct.
Old May 14, 2009 | 11:49 AM
C3 4ME's Avatar
C3 4ME
My headlights worked fine when I only had 12" of vacumn. Maybe I missed it, but did your headlights work before the intake swap? I'm betting the intake is not the problem.
Old May 18, 2009 | 01:34 PM
reddog76's Avatar
reddog76
Cam is a Summit SUM-1103 and the headlights worked fine before the top end rebulid.
Old May 18, 2009 | 01:44 PM
reddog76's Avatar
reddog76
Anyone have any pics? ALso per another thread I just read, How about a 4 hole carb gasket on this 2116? Will that make a difference? Summit gave me that 4 hole and I think it is wrong.
Reddog76
Old May 19, 2009 | 10:17 PM
reddog76's Avatar
reddog76
Any comments on this?? I really need some of your expertise.
To EdelBrock Performer 2116 / headlight vacuum issue
