leaded head conversion?
Old May 13, 2009 | 08:17 PM
greggome's Avatar
greggome
Default leaded head conversion?
I have a 68 coupe 327/350 that I am taking out of storage. Is it easier/cheaper to have the original heads rebuilt to accept unleaded fuel or replace the heads with 70's or later heads that are set up for unleaded fuel?
Old May 13, 2009 | 08:47 PM
Reggie Dunlop's Avatar
Reggie Dunlop
It is easier to replace the heads, and could be cheaper depending on the heads you pick, but you do not have to. Your valves and seats will last a very long time running on unleaded gas. It is largely a myth about the wear to seats and valves. I have run '461s and '462s for years on daily drivers in all weather and all traffic conditions with no ill effects.
Old May 13, 2009 | 09:02 PM
greggome's Avatar
greggome
You havent run into other problems such as damage to pistons or rings? I have heard that with the compression ratio on my 327/350 that running unleaded fuel can cause ping/damage due to the lack of octane/lead in todays gas. I guess this is really a different question from my original one but I'm trying to make sure I dont do any damage. Thanks.
Old May 13, 2009 | 09:09 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I wouldn't worry about it unless you are having problems. Just add octane booster to premium fuel and mtor down the road.
Old May 14, 2009 | 01:33 AM
Scott Marzahl's Avatar
Scott Marzahl
Don't bother with installing hardened seats in those early heads, they don't need it and the castings tend to crack between the seats when done. You should only be at about 10.25:1 compression with a stock build and with a stock L79 cam (which bleeds off a lot of dynamic compression), you will not have any problems running premium pump fuel with a good tune up.
Old May 14, 2009 | 10:28 AM
Mike Ward's Avatar
Mike Ward
http://forums.corvetteforum.com/c3-g...onversion.html
To leaded head conversion?
