long and short headers
Old May 13, 2009 | 10:04 PM
MNTWINS33's Avatar
MNTWINS33
Default long and short headers
Besides the length what is the difference between shorty and long tube headers?
Old May 13, 2009 | 10:54 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
the power curve and total increase in power. collector shape and size as well as primary length and size all work together to change tq curves and hp. the long tube is far superior.
Old May 13, 2009 | 11:01 PM
MNTWINS33's Avatar
MNTWINS33
thats a relief i bought long tube
Old May 13, 2009 | 11:13 PM
MN80Vette's Avatar
MN80Vette
I agree, and I know from experience. I had block hugger shorties on my GM 350 HO crate with true duals. The shorties melted my motor mounts. The shorties ran WAY too close to the spark plug wire boots and melted/cracked them too. I decided to switch to long headers for those reasons.
After I switched to long headers (Dynomax ceramic coated from Summit), I suddenly had a carb problem. Breath in, breath out. The improvement in the breath-out part of the cycle created a too-lean problem on the breath-in end. I ended up upping the accelerator jets and accelerator pump cam on the Holley carb.
Most importantly, the performance improvement was obvious on my butt-o-meter.
Old May 14, 2009 | 01:02 AM
terry82's Avatar
terry82
long tubes are the better header but the shorties dont heat up the starter
Old May 14, 2009 | 02:52 AM
skeeter5070's Avatar
skeeter5070
El Camino
Default long tube headers
Would there be any problem installing long tube headers on my 74 small block ?
I am having my motor overhauled. The block is going to be decked, mild cam, flat teflon pistons, aluminum heads and intake.
But I was told that I have to run shortys because of the clearance ? My Corvette is stock suspension.
Is it possible to run long tube headers ??
Old May 14, 2009 | 03:58 AM
OzzyTom's Avatar
OzzyTom
That's a big statement.
My understanding is long tube headers offer more top end power, by shifting torque peak higher in rpm range, whereas shorter length tubes provide slightly better lower rpm torque.
Tri-Y designs act as a good compromise, and give benefits across whole rpm range.
Old May 14, 2009 | 04:25 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old May 14, 2009 | 07:12 AM
Ganey's Avatar
Ganey
Corvette SB manifolds are good for manifolds & shortys are mainfold replacements. May or may not make more power. Next up are compromise headers like 3/4 length & Tri-Y.
At the top for Corvette SB are full length Dynomax Cerma Coat & Hooker Super Comps.
Old May 14, 2009 | 07:15 AM
Ganey's Avatar
Ganey
Yes, easily.
Old May 14, 2009 | 07:59 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Not true. The length of the tubes in a long tube or tri-y design determine its torque curve.
Readily available long tube headers are tuned for higher RPM motors.
Old May 14, 2009 | 08:25 AM
MN80Vette's Avatar
MN80Vette
I'm not sure where the clearance problems would be or how much of a problem you would really have. I have a non-stock lowered suspension. If my headers hit something, about 3 other places under my car are going to hit too. Here are some pictures that show clearance with full length headers. I clamped a ruler on my rolling lift platform to see exact clearances.
Old May 14, 2009 | 08:26 AM
gerry72's Avatar
gerry72
Primary pipe diameter and collector configuration/length have more imact than anything else (primary length, equal-length) in most street engines -those producing <1.5hp/ci na. Length becomes an influence when you are tuning in a very narrow power band. Equal length is pretty much a non-issue if you aren't running a 180-degree header or a flat crank.
There are always design compromises, though. There is no long-collector, short-tube street header I've ever seen. So you run a shorty with no collector to speak of, or you run long tubes with a suitable collector.
Race engines are something else entirely.
Old May 14, 2009 | 08:28 AM
skeeter5070
El Camino
Default Thank You MN80vett
Thanks..MN80vett I will go with the long tubes...!
To long and short headers
