BB Lifter Installation
Old Feb 5, 2002 | 09:28 AM
bigvette1's Avatar
bigvette1
Default BB Lifter Installation
I need some advice on lifter installation. I have several that clack until really warm. Adjustments don't do it. Questions - Do I soak the new lifters in oil and pump them to fill, or install with lube only? On writeup says one thing and another says the other. Many Thanks.
Old Feb 5, 2002 | 09:37 AM
oger's Avatar
oger
Default Re: BB Lifter Installation (bigvette1)
The last street BB I put together did that also. What was happening was there was air getting trapped in the lifter galleys. I drilled a .040 hole in each of the front lifter galley plugs behind the timing gear. The problem went away and the extra oil on the timing chain can't hurt. There was no loss in oil pressure or any other problems.
Old Feb 5, 2002 | 09:19 PM
Phlash's Avatar
Phlash
Default Re: BB Lifter Installation (oger)
Typically, I will put the new lifters in a clean old butter container
put the lifters standing upright in it
pour oil in the tub until all the lifters are covered
take a push rod and pump the lifter to get most of the air out of the lifter
This helps prime the lifter so that it won't gauld when starting a fresh engine. Also, ditto on the oil galley plugs, but I use a much smaller bit. You can also go the the Chevy house and buy the right size plugs that are pre-drilled. I think Chevy started using these plugs in about 76 to eliminate the oil from boiling and collapsing the lifters. The early 396's and 454's were bad about having the front 4 lifters rattling when hot. Hope this helps.
Phlash 72 BB Roadster :yesnod:
Old Feb 6, 2002 | 12:09 AM
bigvette1's Avatar
bigvette1
Default Re: BB Lifter Installation (Phlash)
Just the info I needed. I think the idea of priming a new "dry" lifter makes god sense. The oil galley plugs hit the mark. It is the front ones that are clacking when hot. Many thanks. ;) [IMG][/IMG]
To BB Lifter Installation
