Transmission Tunnel Insulation
I dropped the body on my 69 last week and realized that I left the tunnel insulation out. It didn't have any when I got the car, but had bought a new replacement. So do I lift the body and install it or leave it out and just insulate the inside of the tunnel area?
If not, you can cut a slit in the side of the insulation where the shifter opening is to go around the shifter.
cc
There are two insulations, the horse shoe, yes I can press that in place, but the large insulation piece is going to be an issue. I have another couple things I need to fix so I guess I will lift the body back off as I just dropped it last week and not much other than the bolts to remove. I also wanted to change a few shims around so I'll bite the bullet and do it all tomorrow.
Seem like a lot of trouble just for the tranny blanket. Can't you maneuver it into place starting at the rear and sliding it forward? I wouldn't even remove the shifter; just cut a slit.
Then press onto the tabs and bend.
Not that simple?
Not that simple?
cc
The right side # 3 mount could use a little more shim and a one less on the # 4. I can get the # 4 out without taking the body up, but the # 3 it has to come up. I also did a T5 swap and it would be a little better to move the shifter a 1/4" to the drivers side and the only way to get the shifter off, then cut and re-weld the bracket where I want it is drop the tranny or lift the body.
Yeah I have nothing else to do..... This is what I did tonight. This is part of my new Forumla Car bodywork that I have to repaint. Lots of pieces, wings etc, as if I didn't have enough to do. This was white, but my cars have to be black!
