OK, since i am doing a head and cam swap i figured i would try to do a roller rocker conversion as well.
i have been reading about taller valve covers, thicker gaskets, parts that supposedly work etc etc
i see that taller valve covers wont work because of the brake booster.
i see where people trim and beat the covers up but other than trimming the drippers id rather not go hard core hammering on them
so basically
anyone with a 454, stock valve covers, and roller rockers.
what all parts did you use, id really appreciate the help in choosing what i will need to put these in.
(if i stick with standard ratio 1.7 rockers normal length pushrods should work right)
A lot depends on if you have the dripper tabs inside. I know the Crowers and Comps will often fit....but remember that many aftermarket heads have the valve cover rail raised 1/4" which really helps with leaks and clearance and even at that often require thicker or double gaskets to clear roller rockers.
This is not a answer as to clearances between the valve covers and rockers. Just a observation on those parts. {1} They are about as bad to adjust as a Hemi. {2} you dont need them as HP improvement is negligible if any at all. A good set of long slot rockers is all that's necessary up to about 600+ HP or where every last ounce of HP is necessary...... anyway
interesting
thats the first time that i have heard that roller rockers are a waste.
i have read often that the roller tip didnt add hp but i keep reading over and over that roller rockers will add hp.
wer2xu how tall are those spacers.
they look huge.
what rockers are underneath the covers and how bad was fitting the covers under the brake booster.
sorry for the questions, i just cant afford to experiment.
You won't measure the HP increase unless you move out to a 1.8 maybe. They don't hurt a thing...and are necessary when you get into more radical cams and higher lifts and spring pressures. Just depends on what you're building.
The stock GM Long slots like used on L-88's and LS-7's will do excellent too. I've run them to 7000+ rpm regularly with nasty flat tappet cams.
I have the xe274 with comp full roller rocker arms under stock valve covers. I had to cut part of the upper nut down where the set screw goes. I also used 2 valve cover gaskets, get the felpro with the metal in between.
good to know,
which comp roller rocker, summit has multiple part #s for them.
interesting
they look huge.
3/4 of inch. I dont have power brakes, but the alternator is very close.
If you tear out the dripper rails, a big fat gasket will work fine.
cool,
what type of spacers, gaskets, valve cover did you use.
Stock valve covers with the drippers and two of the fel pro sandwich gaskets with metal in between. I also had to cut down the adjusting nut on the upper rocker studs. Did this two years ago without any problems and no spacers.
buy the cheap TD valve covers for 69 bucks from summit when you order the harland sharp roller rockers and the felpro thick VC gaskets that cost 40 bucks, you may need to round the corner of the # 1 intake and #8 intake rocker arm to clear the indentation for the bolts. You will need slightly longer bolts, but this will work. Or use the crane roller tip rockers and the cool nuts with the original dripper VC's
interesting
Shortly after I got on the forum, someone asked & I posted roller rockers would not add hp. There seemed to be a stunned silence for awhile. Finally someone backed me up which was good because I was only going to post a few more words no matter how long the topic.
In the beginning of the SB Chevy design some including Smokey Yunick thought roller rockers would add hp. Smokey, under contract, got an agreement to change the design to roller rockers if any hp was added.
Full rollers are needed for high rpm & when spring pressures are high to prevent galling of the ball pivot.
Increase in the rocker ratio can increase power by adding lift & some duration.
There used to be a lot of rocker topics in C3.
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Rollers can and do maintain the ratio better than the stamped steel rockers. Now all rockers will lose ratio as the rocker moves towards the piviot point. But the roller will not slide back on the stud as it pushes down on the valve there by not reduceing the ratio any where near what a slotted rocker will.
