Installing Cam
Old May 17, 2009 | 12:17 PM
1967droptop's Avatar
1967droptop
Default Installing Cam
Building a small block and installed the cam today. While coating the lobes with moly, also coated the cam bearing surfaces with moly. Any problem doing this. Should I have just used oil on the cam bearing surfaces? Thanks for your comments.
Old May 17, 2009 | 12:51 PM
midyearvette's Avatar
midyearvette
no problem here be sure to coat the lifter bottom's too.....
