Help!!! Wiring F
Old May 17, 2009 | 05:48 PM
Neptune75's Avatar
Neptune75
Default Help!!! Wiring F
I have a 1975 l-82 i replaced the entire interior buttoned it up and now my interior lights don't work! so i checked The fuse panel the glass fuse is good. then i checked the current draw on the fuse panel and to my amazement i have no 12v power on either side of the the fuse now i am baffled the entire fuse panel has power ever fuse but the instrument lights. i jumped and i have power at all the light gray lights so my switch and rheostat works just this dead junction any ideas!!
I need a good wiring schematic book any ideas with that too....
Old May 17, 2009 | 06:25 PM
Duke94's Avatar
Duke94
Here is a good schmatic of a 78, but it should be close to your 75', might help you trace the issue.
Gary
http://www.corvetteforum.net/c3/tune.../index19.shtml
http://www.corvetteforum.net/c3/tune...l/index6.shtml
Old May 17, 2009 | 06:40 PM
...Roger...'s Avatar
...Roger...
Make sure when you check this fuse that you have the headlights pulled on....the inst light fuse is fed by the headlight switch rheostat. If the headlights are off the fuse will not be hot.
To Help!!! Wiring F
